Contents » Using WinSCP »
Guides »
Set Up »
Collecting Session Details
- Host name1) of the server2), such as
ftp.example.com. Particularly when connecting to server hosting your website, note that the host name of the server, where you connect to manage the web site may not be the same as your website domain.
- Protocol the server supports (FTP, SFTP, FTPS, etc.);
- Account username;
- Account password3).
Advertisements:
- IT Support department of company you work in;
- IT Support department or university you study at;
- Webhosting company that provides you a website.
Connecting
- Select Session tab (it will be selected already if you are using WinSCP for the first time).
- Enter your host name to Host name field, username to User name and password to Password
- Select your File protocol. When you are about to use FTPS protocol, select FTP and then choose one of the FTPS invocation methods.
- You may want to save your session details to a stored session so you do not need to type them in every time you want to connect. Press Save button and type stored session name.
- Press Login to connect.
