Documentation » Using WinSCP » Guides » Cloud Computing »
Connecting securely to DigitalOcean droplet with SFTP
With WinSCP you can easily upload and manage files on your DigitalOcean droplet/server over SFTP protocol.
Setting up Public Key Authentication
While you can use the root password to login with WinSCP, it is more secure to use a public key authentication.
First you need to generate your key pair, if you do not have one yet:
Easiest way to setup the public key authentication is directly when creating the droplet.
  • In PuTTYgen, copy the contents of Public key for pasting into OpenSSH authorized_keys file to the clipboard;
  • In Authentication > SSH keys section of the Create Droplets form, click New SSH Key;
  • Paste the public key fingerprint from clipboard;
  • And confirm by clicking Add SSH Key button.
If you want to add the key to your existing droplet:
Connecting
Collect information about your droplet:
  • IP address: It is the dotted number in a format aaa.bbb.ccc.ddd below your droplet hostname on the droplet console panel.
  • Host key fingerprint: On the first connect you will be prompted to verify a server host key. While the DigitalOcean documentation suggests you can accept the droplet host key on the first connect without verifying it, to maintain maximum security, you should securely acquire a fingerprint of the host key:
    • Connect to the droplet with the DigitalOcean recovery console;
    • Use the following commands to display fingerprints of the host keys:
      root@droplet:~# ssh-keygen -l -f /etc/ssh/ssh_host_rsa_key.pub
      2048 SHA256:z6YYzqGiAb1FN55jOf/f4fqR1IJvpXlKxaZXRtP2mX8  root@droplet-1 (RSA)
      root@droplet-1:~# ssh-keygen -l -f /etc/ssh/ssh_host_dsa_key.pub
      1024 SHA256:K1kYcE7GHAqHLNPBaGVLOYBQif04VLOQN9kDbiLW/eE  root@droplet-1 (DSA)
Start WinSCP. Login dialog will appear. On the dialog:
  • Make sure New site node is selected.
  • On the New site node, make sure SFTP protocol is selected.
  • Enter your droplet IP address (see above) into the Host name box.
  • Enter root into the User name box.
  • If you are authenticating with the root password:
    • Enter your root password into the Password box.
  • If you are authenticating with the private key:
  • Save your site settings using the Save button.
  • Login using the Login button.
  • Verify the host key by comparing fingerprints with those collected before (see above).
Further reading
Last modified: by martin – Currently locked by: 103.136.203.128
