Following is more robust alternative to simple example contained in guide to SFTP file transfers in .NET.
Imports System Imports System.IO Imports System.Diagnostics Imports System.Xml Imports System.Xml.XPath Imports System.Configuration.ConfigurationManager Public Class SFTP ' SFTP support, built on WinSCP Public Shared Function PutSFTP(ByRef filename As String, ByRef remotehost As String, ByRef username As String, ByRef password As String, _ Optional ByVal outfilename As String = Nothing, Optional ByVal output As String = Nothing, Optional ByRef errmsg As String = Nothing) As Boolean ' Run hidden WinSCP process Dim winscp As Process = New Process() Dim logname As String = Path.ChangeExtension(Path.GetTempFileName, "xml") With winscp.StartInfo ' SFTPExecutable needs to be defined in app.config to point to winscp.com Try .FileName = AppSettings("SFTPExecutable") If .FileName Is Nothing OrElse .FileName.Length = 0 Then Throw (New Exception("from PutSFTP: SFTPExecutable not set in config file.")) Catch ex As Exception errmsg = ex.Message Return False End Try .Arguments = "/log=" + logname .UseShellExecute = False .RedirectStandardInput = True .RedirectStandardOutput = True .CreateNoWindow = True End With Try winscp.Start() Catch ex As Exception errmsg = "from PutSFTP: Could not run the WinSCP executable " & winscp.StartInfo.FileName & Environment.NewLine & ex.Message Return False End Try ' Feed in the scripting commands With winscp.StandardInput .WriteLine("option batch abort") .WriteLine("option confirm off") .WriteLine("open sftp://" & username & ":" & password & "@" & remotehost) If outfilename Is Nothing Then .WriteLine("put " & filename) Else .WriteLine("put " & filename & " """ & outfilename & """") .Close() End With If Not output Is Nothing Then output = winscp.StandardOutput.ReadToEnd() ' Wait until WinSCP finishes winscp.WaitForExit() ' Parse and interpret the XML log ' (Note that in case of fatal failure the log file may not exist at all) If Not File.Exists(logname) Then errmsg = "from PutSFTP: The WinSCP executable appears to have crashed." Return False End If Dim log As XPathDocument = New XPathDocument(logname) Dim ns As XmlNamespaceManager = New XmlNamespaceManager(New NameTable()) ns.AddNamespace("w", "http://winscp.net/schema/session/1.0") Dim nav As XPathNavigator = log.CreateNavigator() ' Success (0) or error? Dim status As Boolean = (winscp.ExitCode = 0) If Not status Then errmsg = "from PutSFTP: There was an error transferring " & filename & "." ' See if there are any messages associated with the error For Each message As XPathNavigator In nav.Select("//w:message", ns) errmsg &= Environment.NewLine & message.Value Next message End If Try My.Computer.FileSystem.DeleteFile(logname) Catch ex As Exception ' at least we tried to clean up End Try Return status End Function End Class
Site design by Black Gate
