Topic "WinSCP password not accepted"
Bangali
New to WinSCP. I am trying to use it to have a simple graphic interface to our dedicated server (CentOS). We have root acces an we can login with Putty or SecureCRT. However the same config does not allow to login with the pwd. This is the log
011-08-16 00:18:36.536 Session name: root@174.xxx.xxx.xxx (Stored session)
. 2011-08-16 00:18:36.536 Host name: 174.xxx.xxx.xxx (Port: 8616)
. 2011-08-16 00:18:36.537 User name: root (Password: Yes, Key file: No)
. 2011-08-16 00:18:36.537 Tunnel: No
. 2011-08-16 00:18:36.537 Transfer Protocol: SFTP
. 2011-08-16 00:18:36.537 Proxy: none
. 2011-08-16 00:18:36.537 SSH protocol version: 2 only; Compression: No
. 2011-08-16 00:18:36.537 Bypass authentication: No
. 2011-08-16 00:18:36.537 Try agent: No; Agent forwarding: No; TIS/CryptoCard: No; KI: No; GSSAPI: No
. 2011-08-16 00:18:36.537 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-08-16 00:18:36.537 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-08-16 00:18:36.537 SFTP Bugs: -,-
. 2011-08-16 00:18:36.537 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-08-16 00:18:36.537 Shell: default
. 2011-08-16 00:18:36.537 EOL: 0, UTF: 2
. 2011-08-16 00:18:36.537 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-08-16 00:18:36.537 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-08-16 00:18:36.537 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-08-16 00:18:36.537 Cache directory changes: Yes, Permanent: Yes
. 2011-08-16 00:18:36.537 DST mode: 1
. 2011-08-16 00:18:36.537 --------------------------------------------------------------------------
. 2011-08-16 00:18:36.602 Looking up host "174.xxx.xxx.xxx"
. 2011-08-16 00:18:36.602 Connecting to 174.xxx. port 8616
. 2011-08-16 00:18:36.825 We claim version: SSH-2.0-WinSCP_release_4.3.4
. 2011-08-16 00:18:36.828 Waiting for the server to continue with the initialisation
. 2011-08-16 00:18:36.998 Detected network event
. 2011-08-16 00:18:36.998 Server version: SSH-2.0-OpenSSH_4.3
. 2011-08-16 00:18:36.998 We believe remote version has SSH-2 ignore bug
. 2011-08-16 00:18:36.998 Using SSH protocol version 2
. 2011-08-16 00:18:36.998 Waiting for the server to continue with the initialisation
. 2011-08-16 00:18:37.164 Detected network event
. 2011-08-16 00:18:37.164 Doing Diffie-Hellman group exchange
. 2011-08-16 00:18:37.164 Waiting for the server to continue with the initialisation
. 2011-08-16 00:18:37.533 Detected network event
. 2011-08-16 00:18:37.533 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-08-16 00:18:37.619 Waiting for the server to continue with the initialisation
. 2011-08-16 00:18:37.816 Detected network event
. 2011-08-16 00:18:37.994 Host key fingerprint is:
. 2011-08-16 00:18:37.994 ssh-rsa 2048 66:0a:99:6d:2e:cb:37:69:a3:a0:af:03:aa:ea:de:37
. 2011-08-16 00:18:37.994 Initialised AES-256 SDCTR client->server encryption
. 2011-08-16 00:18:37.994 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-08-16 00:18:37.994 Initialised AES-256 SDCTR server->client encryption
. 2011-08-16 00:18:37.995 Initialised HMAC-SHA1 server->client MAC algorithm
. 2011-08-16 00:18:38.357 Detected network event
! 2011-08-16 00:18:38.357 Using username "root".
. 2011-08-16 00:18:38.363 Waiting for the server to continue with the initialisation
. 2011-08-16 00:18:38.525 Detected network event
. 2011-08-16 00:18:38.525 Prompt (7, SSH password, , &Password: )
. 2011-08-16 00:18:38.525 Using stored password.
. 2011-08-16 00:18:38.533 Sent password
. 2011-08-16 00:18:38.533 Waiting for the server to continue with the initialisation
. 2011-08-16 00:18:41.208 Detected network event
. 2011-08-16 00:18:41.211 Access denied
. 2011-08-16 00:18:41.211 Prompt (7, SSH password, , &Password: )
. 2011-08-16 00:19:01.978 Sent password
. 2011-08-16 00:19:01.978 Waiting for the server to continue with the initialisation
. 2011-08-16 00:19:04.246 Detected network event
. 2011-08-16 00:19:04.249 Access denied
. 2011-08-16 00:19:04.249 Prompt (7, SSH password, , &Password: )
. 2011-08-16 00:19:07.896 Disconnected: Unable to authenticate
* 2011-08-16 00:19:07.912 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 0.
* 2011-08-16 00:19:07.912 Authentication log (see session log for details):
* 2011-08-16 00:19:07.912 Using username "root".
* 2011-08-16 00:19:07.912 Access denied.
Any help would be appreciated.
Can you see any difference between PuTTY and WinSCP session in the server's log file?
Martin,
I solved the problem changing login with password by a keychain pair. It works fine now. For unkown reason password is not send correctly to our server neither by putty or WinSCP. Excellent product!
