Topic "Synchronizing open files"
Ikke
dear all,
I am using a script to have WinSCP to synchronize files ( SFTP protocol ) from a remote server to a local directory.
Unfortunately the script seems to hang forever when the file is open by another user.
How can I start s script that continues when the source file is open ??
thanks a lot,
guido
