Topic "Bug: Custom commands won't save"
WinSCP 4.3.4 (build 1428)
If you create a custom command with square brackets in the name (I added one called "[GZIPALL]"), close the session, and reopen, all commands will be deleted.
I wasn't able to reproduce the problem. Are you? Can you describe step by step, what are you doing? What configuration storage are you using? INI file or Registry?
