Topic "UNIX machine and special character &"
solyman
Dear Winscp support
I am using WinSCP.com file to got the command line and open ftp session for my UNIX server
when I try to use the order "call" to send and Executes arbitrary remote command I face a certain problem which is
when I type the command
winscp > call /usr/Systems/script/mmlmacro -f /home/alarm/alarm.mjs
the script run and every thing is ok
but when I type the command
winscp > call /usr/Systems/script/mmlmacro -f /home/alarm/alarm.mjs |&
to execute the command in the background I got the following error message
ksh[5]: syntax error at line 7 : `newline or ;' unexpected
I think the error is duoto the spesial character & since the command
winscp > call /usr/Systems/script/mmlmacro -f /home/alarm/alarm.mjs |at now
the command works well
plz help me to solve my problem , I think the error in the way i enter the &(and symbole)
thank you in advance
I believe that & is not supported in non-interactive shells.
solyman
thank you prikryl
this mean it will not work !!!!!!!!
When you are trying to "background a process", I believe you are supposed to just use "&", but you are using "|&". I've never seen "piped to and" before. You normally use pipe when there is another command after the pipe, but just use "&" when you want to "background the process".
As prikryl said this may still not work in non-interactive shells, but I just thought I'd mention that the "|&" looks odd to me, so try it without the "|", just to make sure that don't work either.
You could also try to make mmlmacro background itself...or make a version that will background itself mmlmacro-bg.
solyman
Dear
the problem in the "&" character not in the "|" character
first i tried the "&" and it did not work and i got an error message
so I tried different solution which is using the "|&" and it works in the shell directly but did not work using the call command of the winscp
Very Happy Very Happy Very Happy
