Topic "Error 3 - can't copy files win 7 to ipad!! pls help"
johnnyuk
Hi all, Appoligies in advance but newbie here!
I have Win SCP vsn 5-beta
OS: Win 7 - 64 bit
IPAD 1 on 4.3.5 - jailbroken
Connected WINSCP to ipad with SFTP - no probs
copied files from ipad to pc - again nil issues
Then, when trying the reverse process, copying files from pc to ipad i get the following error message:
System Error. Code: 3.
The system cannot find the path specified
I have run the program as administrator, and the folder is set for share: read/write everyone
I do not have this issue whilst using my macbook and cyberduck - but just really confused Exclamation
what am i doing wrong
Thanks in advance
Can you try the latest stable release WinSCP 4.3.4? Please let me know if it helps.
caio
Had that problem too. I had 4.3.4 installed and working, upgraded to 5 beta and got that same error, went back to 4.3.4 and got it working again.
My system:
Windows 7 Ultimate 32 bits
Intel Core 2 Duo 2.33Hz
2GB Ram
Oh! Btw... WinSCP keeps loosing connection to any ftp server. Tested with other ftp clients and connection did not drop.
RobHam
Most ftp client programs have an option to 'Keep the ftp connection live', needed by some servers during idle trafic periods, the ftp client will send NOOP commands at intervals, sometimes the time interval between sending the NOOP comands is configurable.
Suggest that you could request this feature (assuming that it is missing) as a future enhancement to Winscp when connected using ftp client mode.
RobHam
Suggest that you enable logging and then post the relevant part of the log that shows the lost connection.
WinSCP has it too.
http://winscp.net/eng/docs/ui_login_connection
