Topic "Get Command Within Script"
mcsedude
Trying to make a simple script work. I can delete my files locally, I can log in with winscp but when using the get command to retrieve the files from the remote host it does no work. Here is a kicker, when I run the script and log into the command prompt winscp, I can run the get command and it works just fine. I am missing something in my script. Need some help!! I am using the echo off and pause so I can watch the script work and once the scrit is working I will remove it.
Here is my script.
Session name is test
On the Winscp login session I do have the directories set to
/home/dennis/downloads/test
D:\test123
I have tried using the *.*
Again it all works except the get files. What am I missing?
echo off
del D:\test123\class.csv
del D:\test123\students.csv
option batch on
"C:\Program Files (x86)\WinSCP\WinSCP.com" test
set auto_name=1
set logfile=0
get /home/dennis/downloads/test/class.csv
get /home/dennis/downloads/test/students.csv
pause
Please do not post the same question twice:
http://winscp.net/forum/viewtopic.php?t=10062
