Topic "Fail to set permissions from 0600 to 0700 recursively"
daniela.waranie
WinSCP 4.3.4:
Fail to set permissions from 0600 to 0700 recursively on a directory structure using the "Set group, owner and permissions recursively" option on a FTP connection. I get a error "Could not retrieve directory listing [...]Zend/Feed/Builder/: No such file or directory", when running the command on "Zend" dir.
In fact, the dir "Builder" has 0600 permission at the moment. WinSCP should change the permissions for that dir before requesting a directory listing. Even adding "Add X to directories" option do not help.
PS: How to login / register for the issue tracker? I can not find a link to the registration process.
