Topic "Issue with connecting straight FTP instead of SFTP"
duhaas
As you can see from the log below, it keeps using SFTP as the transfer protocol even though I just want straight FTP, here is the command I'm using:
open miest:testtest.com:21
. 2011-08-29 11:41:40.991 User name: miftp (Password: Yes, Key file: No)
. 2011-08-29 11:41:40.991 Tunnel: No
. 2011-08-29 11:41:40.991 Transfer Protocol: SFTP (SCP)
. 2011-08-29 11:41:40.991 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-08-29 11:41:40.991 Proxy: none
. 2011-08-29 11:41:40.991 SSH protocol version: 2; Compression: No
. 2011-08-29 11:41:40.991 Bypass authentication: No
. 2011-08-29 11:41:40.991 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-08-29 11:41:40.991 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-08-29 11:41:40.991 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-08-29 11:41:40.991 SFTP Bugs: -,-
. 2011-08-29 11:41:40.991 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-08-29 11:41:40.991 Shell: default
. 2011-08-29 11:41:40.991 EOL: 0, UTF: 2
. 2011-08-29 11:41:40.991 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-08-29 11:41:40.991 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-08-29 11:41:40.991 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-08-29 11:41:41.007 Cache directory changes: Yes, Permanent: Yes
. 2011-08-29 11:41:41.007 DST mode: 1
. 2011-08-29 11:41:41.007 --------------------------------------------------------------------------
. 2011-08-29 11:41:41.007 Looking up host "ptaftp.ptaconnect.com"
. 2011-08-29 11:41:41.194 Connecting to 147.249.149.21 port 21
. 2011-08-29 11:41:56.272 Waiting for data timed out, asking user what to do.
. 2011-08-29 11:41:56.272 Asking user:
. 2011-08-29 11:41:56.272 Host is not communicating for 15 seconds.
. 2011-08-29 11:41:56.272 Wait for another 15 seconds? ()
. 2011-08-29 11:41:56.272 Attempt to close connection due to fatal exception:
* 2011-08-29 11:41:56.272 Terminated by user.
. 2011-08-29 11:41:56.272 Closing connection.
. 2011-08-29 11:41:56.272 Sending special code: 12
So what did you do to select FTP protocol?
