| Author | Message |
Posted: 31 Aug 2011 08:16
I'm running winscp beta 5 under win XP.
In the applications panel a tag showing that winscp runs has a generic window icon instead of winscp icon. |
poodledoodle
Guest |
Posted: 3 Sep 2011 00:38
Yes, apparently winscp.exe doesn't contain an icon in both the standalone and installed versions. This makes it hard to spot WinSCP in the task bar if you have many other windows open.
prikryl
Posts: 16466 Location: Prague, Czech republic |
Posted: 4 Sep 2011
Thanks for your post.
This bug has been added to the tracker: http://winscp.net/tracker/show_bug.cgi?id=722 |
| Advertisements |
Site design by Black Gate
