Topic "Append Login details after opening the WinSCP exe"
Am using the below command to open the WinSCP exe & to pass the Hostname & port, it works fine
START "C:\Program Files (x86)\WinSCP3\WinSCP3.exe" s -hostkey="18"
Can someone please let me know how to append login details to the above line (Username & password)
UserName: country
Password: c0unTRY
Tried with the syntax given : but it was not working
Some one help me on this plssssssss Confused
Thanks in Advance
The syntax in the referenced post should work.
For details refer here:
If it does not help, you need to post a log file. Also make sure you are using the latest stable version, what you seem not to.
