Topic "winSCP 5 "500 invalid PORT command"
anlu42
I have recently upgraded to WinSCP 5 (Build 1431) (WinXP fully updated)
and since then I can not access a server which I frequently have been using for uploading files.
The connection is made via FTP
Check complete log of connection and login
http://pastebin.com/DN6c4bZG
Edit:
I can connect to server but not browse directories etc.
Can you post a log file also from version that used to work?
anlu42
here is the log:
http://pastebin.com/7SGQDvaM
I still get the "UNC paths are not supported"-error but I can now see the remote directory and browse it.
BTW I think I forgot to say I use "Commander"
In 4.3.4 you are using passive mode, while in 5.0 you are not.
anlu42
Hmm in 4.3.4 I have no recollection of making an active choice.
Thanks for the help.
How about the UNC path error which shows up in both versions?
Ankur Jain
I am getting same error message when i am trying to connect to putty from winscp. It is working in latest final version. Thanks for your help
Ankur Jain
Sad
What version of WinSCP are you using? Have you tried 5.0.1 beta?
anlu42
I tried installing 501 but after installation it doesn't start.
Reverted to 4.3.4 and all works fine, still UNC-path error but I can use the software.
Why it did not start? Were you getting this error?
http://winscp.net/tracker/show_bug.cgi?id=729
If you did, 5.0.2 should work for you.
anlu42
Don't know why, got no error message simply no reaction to double-click other then a flicker of an hour-glass. I'll try 5.02
5.02 works fine.
Still UNC-paths but as far as I can detect it is only one server.
Edit: I had \\servername\folder1\folder2\ as "home directory" for this session and when I changed it to c:\Documents...\username\Desktop it works fine. No UNC-path error
