Topic "v5.0.0 (Build 1431) Final install dialog issues."
icebrkr
Just installed WinSCP v5.0.0.0 (Build 1431) on a fresh install of Windows 7 Professional. The final dialog of the install is a bit messed up. I assume this has something to do with the new UTF-8/Unicode stuff? Screenshot below.
http://imgur.com/FeENi
Also, I've noticed there's no embedded icon with-in the executable. I noticed a program of mine has a hard time dealing with this. Previous versions of WinSCP worked. So probably just an issue with the new v5 build.
Thanks for your post. The installer is not Unicode yet. So it should not be related. Can you try again the installer of 4.3.4? Let me know.
This bug is tracker here:
http://winscp.net/tracker/show_bug.cgi?id=722
