Topic "5.0.1 Beta: GetTimeZoneInformationForYear Error in kernel32"
franc
With 5.0.1 Beta I have the following error when starting, so just after installing before the first start:
Der Prozedureinsprungpunkt "GetTimeZoneInformationForYear" wurde in der DLL "KERNEL32.DLL" nicht gefunden.
This is german and could mean:
The procedure entry point "GetTimeZoneInformationForYear" could not be located in the dynamic link library "Kernel32.DLL
I installed previously 5.0 beta over stable 4.3.4 and this beta worked (without icon only).
My System is Windows XP SP3 Prof.
Kind regards,
franc
Thanks for your post. This bug was added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=729
Also, I have sent you an email with development build for testing. Thanks.
franc
Yes, this version is working, I will use it and look if all is good.
What was it?
Dr. Seltsam
Hi there,
it seems there has been no OS version checking before the call of this function since it is only available as of Windows Vista. I got the same error on my XP box.
See:
http://msdn.microsoft.com/en-us/library/bb540851%28v=vs.85%29.aspx
--TheDoctor
