Topic "Can't close terminal window"
jsmoller
Hello...
I'm having a problem with WinSCP 3.5 in that I cannot close the terminal window. The window appears to be cut off on the right side and there is no X button. I can enlarge the window but nothing else diusplays. Running Win2k Pro SP-4 1024x768 large fonts.
Jan
OK, I'll try to look at this. I guess that you may close the window using Alt-F4 shortcut.
jsmoller
Yes, ALT-F4 works... However in the 3.4.x versions, the X box (upper right-hand corner worked). I need the larger fonts due to eyesight problems. I have had this issue with several software products... Something has changed in the development envvironments...
I'd appreciate it if you could investigate this with your product.
Jan
jsmoller@tpg.com.au
