Topic "Copying files"
Elfmuse
Command failed with return code 1.
Please read this topic: "Copying files from remote side failed".
Lorgan
I am also having the same problem. My friend who also accesses the same remote server does not have this problem, so I guess it must be something on my local end, right?
lorgan
Is your friend using WinSCP too? If he do, problem is probably of remote end. You probably have different settings (default shell or so). You may also try SFTP, which should be more easier to setup.
