Topic "custom session name creation pattern/settings"
consistency
if i save a session with the hostname "example.com" and the user "root", it will add a default name in the save field as: "root@example.com"
this is quite unhandy if you have multiple servers with root users and a different user, in the session list the will get sorted like:
root@alpha.com
root@beta.com
root@example.com
root@gamma.com
anton@alpha.com
beate@beta.com
conrad@gamma.com
so they are not sorted by server but by username.
i always rename the session like this:
example.com: root
example.com: username
so everything is sorted by server
would it be possible to:
- add my pattern (#hostname: #username) to switch per checkbox (defaultSessionName=0/1 in the ini file)
or
- allow a custom pattern to be defined in the ini file (defaultSessionName="--#hostname: || #username--"
Thanks for your post.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=736
