Topic "Problem accepting certificate automatically"
heimdall2013
I am exeucuting a script which executes the following command:
> C:\"program files"\winscp\winscp.exe /ini="D:/Conf.ini" /console /log="D:\Log.log" /command "open ftps://user:pass@SERVER.COM -passive -certificate=""xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx""""" "option transfer binary""" "option confirm off""" "cd """ "put D:\*.*""" "exit"""
And my log shows the following prompt which I can't answer since I am executing it from a script:
> Continue connecting and store the certificate? ()
I have accepted manually, but when running the script it keeps showing the question.
Do any of you know how could I accept this from the command? I have added the -certificate (with the fingerprint shown in the log) to my command and still can't make it work
This is what my log shows
> Connecting to XXX.XXX.XXX.XXX:XXX ...
> Connected with XXX.XXX.XXX.XXX:XXX, negotiating SSL connection...
> Asking user:
> The server's certificate is not known. You have no guarantee that the server is the computer you think it is. Server's certificate details follow:
> Issuer:
> - Organization: XXXXXXXXXX
> - Location: XXXXXXXXXX
> Subject:
> Valid: 7/26/2011 12:00:00 AM - 7/27/2012 11:59:59 PM
> Fingerprint (SHA1): xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
> Summary: Self signed certificate in certificate chain. The error occured at a depth of 3 in the certificate chain.
> If you trust this certificate, press Yes. To connect without storing certificate, press No. To abandon the connection press Cancel.
What version of WinSCP are you using? Make sure you have the latest (stable) one.
heimdall2013
I am using:
WinSCP Version 4.2.5 (Build 624) could the version be the reason of the problem?
That should be OK. But anyway, please upgrade and post a log file.
Tanveer_Munavar
. 2014-09-04 11:32:02.895 Connecting to aft.XXX.com:990 ...
. 2014-09-04 11:32:03.015 Connected with aft.XXX.com:990, negotiating TLS connection...
. 2014-09-04 11:32:03.255 Verifying certificate for "WW00057P.XXXXXX.com" with fingerprint XXXX:7b and 18 failures
. 2014-09-04 11:32:33.265 Asking user:
. 2014-09-04 11:32:33.265 **The server's certificate is not known. You have no guarantee that the server is the computer you think it is.**
. 2014-09-04 11:32:33.265 Server's certificate details follow:
. 2014-09-04 11:32:33.265 Issuer:
. 2014-09-04 11:32:33.265 - Organization: WW00057P.XXXX.com, WW00057P.XXX.com, WW00057P.XXX.com, admin@W
. 2014-09-04 11:32:33.275 - Location: US, US, WW00057P.oneabbott.com
. 2014-09-04 11:32:33.275 Subject:
. 2014-09-04 11:32:33.275 - Organization: WW00057P.XXX.com, WW00057P.oneabbott.com, WW00057P.XXX.com, admin@W
. 2014-09-04 11:32:33.275 - Location: US, US, WW00057P.XXXX.com
. 2014-09-04 11:32:33.275 Valid: 5/14/2010 6:44:23 PM - 5/14/2011 11:44:19 PM
. 2014-09-04 11:32:33.275 Fingerprint (SHA1): XXXXXXXXXXX
. 2014-09-04 11:32:33.275 Summary: Self signed certificate. The error occurred at a depth of 1 in the certificate chain.
. 2014-09-04 11:32:33.275 Certificate was not issued for this server. You might be connecting to a server that is pretending to be "aft.oneabbott.com".
. 2014-09-04 11:32:33.275 If you trust this certificate, press Yes. To connect without storing certificate, press No. To abandon the connection press Cancel.
. 2014-09-04 11:32:33.275 Continue connecting and store the certificate? ()
. 2014-09-04 11:32:33.275 Peer certificate rejected
. 2014-09-04 11:32:33.275 Disconnected from server
Im using winscp 5.6.1 (beta) | Windows 2008 R2 | Powershell V3
FTP server does not have a finger print
    #Load WinSCP .NET assembly
    [Reflection.Assembly]::LoadFrom("C:\Program Files (x86)\WinSCP\WinSCPnet.dll") | Out-Null
    $now = Get-Date
    write-host "`nwinscp assemly is loaded successfully --- $now `n"
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::ftp
    #$sessionOptions.FtpMode = [WinSCP.FtpMode]::Passive
    $sessionOptions.FtpSecure = [WinSCP.FtpSecure]::Implicit
    $sessionOptions.HostName = "aft.XXXXX.com"
    $sessionOptions.UserName = "adcbiarvtp"
    #$sessionOptions.PortNumber = "21"
    $sessionOptions.password = "Spring!14"
    #$sessionOptions.SshHostKeyFingerprint = "FTP server does not have a finger print"
    $now = Get-Date
    write-host "setting up new session --- $now `n"
    $Session.SessionLogPath = “E:\Scripts\Logs\test.txt"
    #Connect to the FTP server
With FTPS, you need to use SessionOptions.TlsHostCertificateFingerprint:
http://winscp.net/eng/docs/library_sessionoptions
