Topic "Help with VB script"
I'm a total newbie at this and now my way around VB, I would like to have a script where I drop a folder, I extract the folder name and connect to a NAS where I want it to move this specific folder from one place to another with MV.
I started to make a test, but I get an error on row exec.StdIn.Write(
Set objArgs = WScript.Arguments
'WScript.Echo WScript.Arguments.Count
myFolder = Split(objArgs(0),"\")
intIndex = Ubound(myFolder)
WScript.Echo myFolder(intIndex)
Set shell = WScript.CreateObject("WScript.Shell")
'run (make it log to XML)
shell.Exec("""C:\Program Files (x86)\WinSCP\WinSCP.exe""")
' feed the commands
exec.StdIn.Write("option batch abort\n" + "open Nas\n" +"ls /share/HDA_DATA/Test\n" +"exit\n")
'wait until it finishes and collect its output
StdOut.ReadAll()
'optionally print the output
WScript.Echo(output)
Suggestions how I can get this to work ?
You need to store the result of shell.Exec call to variable exec taht you are using line below:
var exec = shell.Exec("""C:\Program Files (x86)\WinSCP\WinSCP.exe""")
See documentation:
http://winscp.net/eng/docs/guide_automation_advanced#inout
Thanks !
set exec = shell.Exec("""C:\Program Files\WinSCP\WinSCP.exe""")
' feed the commands
exec.StdIn.Write("option batch abort\n" + "open Nas\n" +"ls /share/HDA_DATA/'test\n" +"exit\n")
set output = exec.StdOut.ReadAll()
Now it starts winscp, but it does not login and do the ls part. and logging in manually and quit Winscp gives me Objext required: '[string:""]' on set output row.
Suggestions ?
Turn on session logging to file and inspect the log. If you do not find anything, post it here.
