Topic "Server sent command exit status 255"
dashah76
Hi
when i install openssh 3.8 on windows xp it works with the public key authentication without any error,but when i install on windows 2003 it gives an error below in the log
Authenticating with public key "rsa-key-20110930"
Waiting for the server to continue with the initialisation
Detected network event
Access granted
Opened channel for session
Started a shell/command
Please read documentation:
http://winscp.net/eng/docs/message_exit_status_1
dashah76
prikryl wrote:
changed the shell in winscp to /bin/bash and sftp server to /bin/sftp-server from winscp tab .still getting the same error.this eeror occurs in windows 2003.i can succesfull login with public key authentication from a openssh server installed on windows 2000/XP
Have you checked server's logs?
dashah76
2011-10-11 00:21:20.299 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-10-11 00:21:20.424 Host key fingerprint is:
. 2011-10-11 00:21:20.424 ssh-rsa 1024 64:c0:9a:53:2b:3e:77:86:d5:7e:4c:31:fd:3d:64:23
. 2011-10-11 00:21:20.424 Initialised AES-256 SDCTR client->server encryption
. 2011-10-11 00:21:20.424 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-10-11 00:21:20.424 Initialised AES-256 SDCTR server->client encryption
. 2011-10-11 00:21:20.424 Initialised HMAC-SHA1 server->client MAC algorithm
. 2011-10-11 00:21:20.439 Reading private key file "C:\Documents and Settings\Administrator\Desktop\ss3.ppk"
! 2011-10-11 00:21:20.439 Using username "test1".
. 2011-10-11 00:21:20.470 Offered public key
. 2011-10-11 00:21:20.486 Offer of public key accepted
! 2011-10-11 00:21:20.486 Authenticating with public key "rsa-key-20111011"
. 2011-10-11 00:21:20.533 Access granted
. 2011-10-11 00:21:20.549 Opened channel for session
. 2011-10-11 00:21:20.564 Started a shell/command
. 2011-10-11 00:21:20.564 --------------------------------------------------------------------------
. 2011-10-11 00:21:20.564 Using SFTP protocol.
. 2011-10-11 00:21:20.564 Doing startup conversation with host.
> 2011-10-11 00:21:20.564 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2011-10-11 00:21:20.595 Server sent command exit status 255
. 2011-10-11 00:21:20.611 Disconnected: All channels closed
* 2011-10-11 00:21:20.611 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 255.
* 2011-10-11 00:21:20.611 Cannot initialize SFTP protocol. Is the host running a SFTP server?
The
dashah76
The evenid gives this erorr as below
Event Type: Error
Event Source: sshd
Event Category: None
Event ID: 0
Date: 10/11/2011
Time: 12:21:20 AM
User: NT AUTHORITY\SYSTEM
Computer: TEST-SFTP
Description:
The description for Event ID ( 0 ) in Source ( sshd ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: sshd : PID 264 : fatal: setreuid 1003: Permission denied.
Maybe this post helps you:
http://cygwin.com/ml/cygwin/2004-05/msg00862.html
