Topic "Scripting RM and not get prompted"
Chrishov
Im trying to remove the contents of my root SFTP directory before I upload a new file. Unfortunatly it promts me to say Y or N.
Here is a basic look at what im doing.
# clear contents on SFTP server
rm *
# Upload the file to current working directory
put E:\upload\*.zip
Problem is the option confirm off does not appear to work for the "rm" command
Ive searched the documentaion and have not figured out how to accomplish this. Can anyone point me in the right direction?
Thanks in advacne.
Chris
I'm not aware of any prompt with rm command.
Can you post a screenshot?
chrishov
My bad. I was mistaking the prompt for the rm command but it was for a del command in my batch file. Thanks for the quick reply though
I am trying to remove a file in a VM and put a new file with the same name in that directory. But somehow the file is not getting removed. When i tried to remove the file manually it is throwing a prompt asking " remove regular file xxx.xml?". how can I input yes into this prompt when run from bat script.
Below is the code i am using:
"C:\Program Files (x86)\WinSCP\WinSCP.com" username:passwrd@xx.xxx.xxx.xxx "option confirm off" "option batch abort" /command "rm /usr/local/web.xml" "put e:\web.xml /usr/local/web.xml" "exit"
Thanks in advance!!
The rm command does not ask for configuration.
Can you show us a screenshot?
