Topic "Queue Columns in Commander for Background Transfers"
I am afraid I have done something silly.
After successfully using WinSCP for some time, now in the Commander Interface I only get the columns:
Operation Source Destination Progress
I no longer get 'Time Elapsed' or 'Estimated Time'.
How did I turn these off?
How can I turn them back on?
Calculate Total Size is 'checked'.
Shall I re-install?
I did not already upgrade because of the 'Beta' status of 5xx
And I also figure the problem is not software, but is me.
Version 4.2.1
The problem just started. I cannot trace it to after upgrade, etc...
Windows Vista Ultimate
SFTP with allow SCP fallback (Connects with SFTP-3)
Commander Style GUI
No Error Message
Drag and drop to upload or download
Haven't seen the problem before.
Try deleting following registry key (make sure WinSCP is not running while doing that):
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\QueueView
I cannot find the key in that location.
There is a:
HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\QueueView
(no Interface sub-key prior to QueueView)
In any case I deleted it. This fixed the problem.
Thank you!
