Topic "Disable dotted selection border - 5.02 beta"
dmex
It's possible to disable the dotted selection border (focus rectangles) when the Explorer listview style is enabled by sending a WM_CHANGEUISTATE message at initialization of the Listview/Treeview.
More information is available here: http://blogs.msdn.com/b/oldnewthing/archive/2005/05/03/414317.aspx
At initialization:
// Make sure focus rectangles are disabled.
SendMessage(ListViewHwnd, WM_CHANGEUISTATE, MAKELONG(UIS_SET, UISF_HIDEFOCUS), 0);
At Runtime in your WndProc callback to keep focus rectangles disabled if the user uses the keyboard to select items.
case WM_UPDATEUISTATE:
// Disable focus rectangles by setting or masking out the flag where appropriate.
switch (LOWORD(wParam))
case UIS_SET:
wParam |= UISF_HIDEFOCUS << 16;
break;
case UIS_CLEAR:
case UIS_INITIALIZE:
wParam &= ~(UISF_HIDEFOCUS << 16);
break;
break;
There is also some nastly flickering of the ListView controls while moving/hovering the mouse over items, Sending the control a LVS_EX_DOUBLEBUFFER message will allow the ListView controls to paint smoothly. Wink
Well, I believe the focus rectangle should be there when using the keybord, shouldn't it? So that you know what item (out of many selected) has the focus.
Will check.
dmex
The problem is that once it's reactivated by the keyboard it stays activated for the lifetime the application is running.
You can still see the last item selected by the keyboard without focus rectangles as it's darker than the other items, Explorer also does this on Vista/7 if you want an example Wink
I'm sorry, but I do not underastand. Can you post a screenshot?
I've tried. But the flickering is even worse then. Would require more investigation. So I've postponed it.
