Topic "WinSCP disappears upon successful connect"
double-click
Windows 7 latest updates (Oct 13, 2011 see the log).
Crash occurs with fresh install of WinSCP 5.02 beta and 4.3.5, as well as with portable versions.
Upon connecting to a server successfully, the connection authentication dialog goes away, followed be the connection log behind it (normal stuff), and then the usual commander style interface does not open. There is no GUI associated with the still running WinSCP process. I cannot find it using alt-tab. There is nothing there. Here's my log.
http://pastebin.com/Q1KpJ9GN
I saw a similar issue that didn't really have a solution posted so I thought that this should probably come up again.
I have sent you an email with link to a debug version.
orion205
Is there any resolution to this bug. I am seeing this same behavior with 4.3.7. Thanks.
orion205
And about 10 seconds after I posted, the WinSCP window shows up! How did it know?!?! Cool
There was a delay of a good 10 minutes between my login and the WinSCP commander-style window showing up.
Are you able to reproduce this using 5.0.6 beta?
orion205
I just loaded 4.3.9, and I don't see this issue. Thanks!
Cr4xy
The title says it all.
How do you run WinSCP? Did you try to run WinSCP with the factory defaults? winscp.exe /ini=nul - Does it work then?
