Topic "Message From server: 141 Can't open log file 'D:\\log.xml'"
tdguitar
Please help me to check this problem when logging the action by winscp from client.
I publish the sample code below in server:
        const string log_path = "log.xml";
        Process winscp = new Process();
        winscp.StartInfo.FileName = "C:\\program files\\winscp\\winscp.com ";
        winscp.StartInfo.Arguments = "/log=D:\\" + log_path;
        winscp.StartInfo.UseShellExecute = false;
        winscp.StartInfo.RedirectStandardInput = true;
        winscp.StartInfo.RedirectStandardOutput = true;
        winscp.StartInfo.CreateNoWindow = true;
        winscp.Start();
        winscp.StandardInput.WriteLine("option batch abort");
        winscp.StandardInput.WriteLine("option confirm off");
        winscp.StandardInput.WriteLine("open mysession");
        winscp.StandardInput.WriteLine("ls ");
        winscp.StandardInput.Close();
        string output = winscp.StandardOutput.ReadToEnd();
        winscp.WaitForExit();
But the value of output is like that when I run from client:
winscp> option batch abort
batch abort
winscp> option confirm off
confirm off
winscp> open user:pass@ip_host
141 Can't open log file 'D:\\log.xml'.
And when I check on the hard disk D in server, there's no log file created. Please check and help me ASAP.
Make sure the account that runs the script has write access to C:\
I checked on the iis server that account have full access right. Please check for me that is there anything I need to check more?
The error message is " 141 Can't open log file D:\log.xml".
Thanks for reply.
Okie, I found out the problem. The problem is lacking add the permission for NETWORK_SERVICE.
Thanks for your support.
hinnman
The weird part is that it gives the 141 can't find log file, but it still writes to the log.
tom dot owens at yahoo dot com
Balaji
Still I am facing same error. As mentioned above i added network service account for my logs folder. Can anyone please please halp me asap. Thanks.
batch abort
confirm off
winscp> open sftp://xxUser@xxx.56.xxx.96:22 -privatekey="C:\FTP_Automation\privatekey.ppk"
141
Can't open log file '.\log\scpLog.xml'.
Searching for host...
Connecting to host...
What is command-line you use to run WinSCP? What is startup directory of the command? What is a path to the log folder?
Balaji
Thanks for your quick reply.
Actually I prepared console application,if I run manually script is working fine. when i automate using windows task scheduler the problem is happening.
I have placed my .exe in following location in a server. C:\FTP_Automation\HRIQ_OTS_FTP. The logs will generate in following location. C:\FTP_Automation\HRIQ_OTS_FTP\logs\.
I have given full access permission as well as I added Network Service account to the "HRIQ_OTS_FTP" folder.
Below is my sample winscp code.
winscp.StartInfo.FileName = ClientPath;
winscp.StartInfo.Arguments = "/log=" + ClientLog;
winscp.Start();
winscp.StandardInput.WriteLine(string.Format("open sftp://{0}@{1}:{2} -privatekey=\"{3}\"", HostUser, HostIP, HostPort, PrivateKey));
winscp.StandardInput.WriteLine(string.Format("StartInfo Argument {0}", winscp.StartInfo.Arguments.ToString()));
winscp.StandardInput.WriteLine(string.Format("cd {0}", HostRoot));
winscp.StandardInput.WriteLine(string.Format("lcd {0}", ClientRoot));
winscp.StandardInput.WriteLine("option transfer binary");
out put:
confirm off
winscp> open sftp://hriqftp@210.56.134.96:22 -privatekey="C:\FTP_Automation\HRIQFTPKeys\privatekey.ppk"
141
Authenticating...
Using username "hriqftp".
Authenticating with public key "rsa-key-201xxx22".
Authenticated.
EXE location is not the same as startup/working directory. Try setting winscp.StartInfo.WorkingDirectory. Also try using absolute path to an INI file.
Balaji
Thank you very much Martin Prikryl. Its working fine after I set the winscp.StartInfo.WorkingDirectory= path of exe folder.
Once again Thank you very much. You saved lot of my time.
Regards,
Balaji
