Topic "Unknown Command '????' in C# .Net Application"
dwentz
I have the code listed below which is basically a modified version of the C# .NET example provided on the WinSCP site. When I print the standard output to a log it shows the command being passed in as ???? instead of "open test". No matter what command is passed in it gets translated to question marks. Is this possibly an encoding issue. This is a .NET 4 Framework application.
Code
Process winscp = new Process();
      winscp.StartInfo.FileName = "winscp.com";
      winscp.StartInfo.Arguments = "/log=\"log.xml\"";
      winscp.StartInfo.UseShellExecute = false;
      winscp.StartInfo.RedirectStandardInput = true;
      winscp.StartInfo.RedirectStandardOutput = true;
      winscp.StartInfo.CreateNoWindow = true;
      winscp.Start();
      winscp.StandardInput.WriteLine("open test");
      string output = winscp.StandardOutput.ReadToEnd();
      TraceService(output);
Output in log file
winscp> ????
Unknown command '????'.
winscp>
halka
Heh, I've actually registered right now to ask the exact same question. Appears in the 5.0.3 beta I'm using, stable version is unaffected. My particular problem exists with scripting from Python 2.7/3.2
dwentz
prikryl wrote:
I have sent you an email for the debug version
shantanu
Same problem i am facing can u tell me the solution ???
my email is shantanu...@gmail.com
I have sent you an email.
RaymondHasty
I'm facing same problem... RaymondHasty@ComCast.Net
