Topic "problem with utf-8 encoding"
Majed
it seems winscp opens files with its editor not in utf-8 format which causes problems when there are other than english characters in the file. i had to copy the file to local computer and open it in total commander and save as utf-8 format and then recopy it back to linux for the configuration to work. so i suggest that this is an essential feature in future versions.
Majed
i should have maybe posted this in the bug report...
This issue is tracked here:
http://winscp.net/tracker/show_bug.cgi?id=78
Meanwhile you can configure an external editor in WinSCP that supports UTF8:
http://winscp.net/eng/docs/ui_editor_preferences
Majed
it seems this has been present for a long time and no one doing anything about it.
