Topic "config.php:"
ProxyNL
I cannot copy or move a file named (for example) config.php:
(no the : is no mistake)
WinScp won't copy it.
Perhapps can someone tell me how to copy it.
ProxyNL
Do you want to download it?
Note that Windows does not allow : in file name.
But anyway, WinSCP should replace the : automatically on download.
See: https://winscp.net/eng/docs/ui_transfer_custom#filename_modification
ProxyNL
Yes, and it is a Linux file...
I use WinSCP mainly to copy files from my Linux Server to the desktop.
