Topic "Problem with SFTP and UTF8 encoding"
JoeMue
Hello!
Support for utf8-encoding when using SFTP does not work. Although I set utf8-encoding for file names in the environment to yes, file names and directories are displayed wrong. German umlaute (, , ) are displayed in their isolatin representation of the ut8 encoded string.
Example: "Büro" instead of "Bro"
This does not seem to be a server problem. All other clients I tried (and I tried them all... FileZilla, CoreFTP, SmartFTP, WS_FTP, ...) display these names correctly.
Jochen
DonD
Hello @all!
I'm new in here and I saw this topic during my attempt to solve the same Problem which is described in here.
I would be glad if someone could help me by giving me a solution.
Thank's a lot.
Greets DonD
You have to give us a way more information.
What protocol? What UTF-8 setting do you use? Did you try the other options?
Did you read http://winscp.net/eng/docs/faq_utf8 ?
DonD
Hello Martin!
I'm using WinSCP 5.5.0,
Settings:
SFTP, if rejected, use FTP;
Language: German;
Default Encoding: UTF-8;
I've allready read the other options, but I didn't find any further Settings.
Thanks for your help.
There's no "SFTP, if rejected, use FTP" mode. So what protocol do you use, SFTP or FTP?
What value do you use for UTF-8 encoding for filenames?
DonD
Sorry, i'm running late, but it's very busy in here...
I use SFTP and UTF-8.
But to give you some more information i've attached some files.
Description: Encoding
Description: Session and Connection
It says "knock", not "use".
"UTF-8 Encoding for Filenames" option is here:
https://winscp.net/eng/docs/ui_login_environment#utf
The option you are showing is for the internal editor.
So where do you get the problem with UTF-8? In the file names (what this topic is about) or in the internal editor?
