Topic "High port issue"
AlexF
Just did some security tweaking and changed my ssh to a high port number. This has been the only thing that I have changed recently.
I am able to login properly, but whenever I try to upload, rename a file, create directory I receive an error. My log follows:
Type: SSH_FXP_INIT, Size: 5, Number: -1
Type: SSH_FXP_VERSION, Size: 5, Number: -1
SFTP version 3 negotiated.
Type: SSH_FXP_EXTENDED, Size: 38, Number: 200
Type: SSH_FXP_STATUS, Size: 38, Number: 200
Status/error code: 8
Server does not recognise WinSCP.
Getting current directory name.
Getting real path for '.'
Type: SSH_FXP_REALPATH, Size: 10, Number: 272
Type: SSH_FXP_NAME, Size: 47, Number: 272
Real path is '/usr/home/xxx'
Listing directory "/usr/home/xxx".
Type: SSH_FXP_OPENDIR, Size: 22, Number: 523
Type: SSH_FXP_HANDLE, Size: 13, Number: 523
Type: SSH_FXP_READDIR, Size: 13, Number: 780
Type: SSH_FXP_NAME, Size: 2437, Number: 780
Type: SSH_FXP_READDIR, Size: 13, Number: 1036
Reading symlink "www".
Type: SSH_FXP_READLINK, Size: 26, Number: 1299
Type: SSH_FXP_STAT, Size: 26, Number: 1553
Type: SSH_FXP_STATUS, Size: 28, Number: 1036
Type: SSH_FXP_NAME, Size: 43, Number: 1299
Type: SSH_FXP_ATTRS, Size: 37, Number: 1553
Status/error code: 1
Type: SSH_FXP_CLOSE, Size: 13, Number: 1796
Type: SSH_FXP_STATUS, Size: 24, Number: 1796
Status/error code: 0
Startup conversation with host finished.
Cached directory change via "public_html" to "/usr/home/xxx/public_html".
Listing directory "/usr/home/xxx/public_html".
Type: SSH_FXP_OPENDIR, Size: 34, Number: 2059
Type: SSH_FXP_HANDLE, Size: 13, Number: 2059
Type: SSH_FXP_READDIR, Size: 13, Number: 2316
Type: SSH_FXP_NAME, Size: 2945, Number: 2316
Type: SSH_FXP_READDIR, Size: 13, Number: 2572
Type: SSH_FXP_STATUS, Size: 28, Number: 2572
Type: SSH_FXP_CLOSE, Size: 13, Number: 2820
Type: SSH_FXP_STATUS, Size: 24, Number: 2820
Creating directory "live".
Canonifying: "live"
Getting real path for '/usr/home/xxx/public_html/live'
Type: SSH_FXP_REALPATH, Size: 39, Number: 3344
Type: SSH_FXP_NAME, Size: 81, Number: 3344
Real path is '/usr/home/xxx/public_html/live'
Canonified: "/usr/home/xxx/public_html/live"
Type: SSH_FXP_MKDIR, Size: 43, Number: 3086
Type: SSH_FXP_STATUS, Size: 34, Number: 3086
Status/error code: 3, Message: 3086, Server: Permission denied, Language: ?
Asking user:
Can't create folder 'live'. ("Permission denied.
Error code: 3
Error message from server: Permission denied (?)
Request code: 14")
Copying 1 files/directories to remote directory "/usr/home/xxx/public_html/"
PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No; FnCs: N; RIC: Yes; Resume: S (102400); CalcS: Yes; Mask: *.*
TM: M; AscM: *.*htm*; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
File: "C:\Documents and Settings\My Documents\xxx"
Copying "C:\Documents and Settings\My Documents\xxx" to remote directory started.
Binary transfer mode selected.
Checking existence of file.
Type: SSH_FXP_LSTAT, Size: 56, Number: 3591
Type: SSH_FXP_STATUS, Size: 29, Number: 3591
Status/error code: 2
Checking existence of partially transfered file.
Type: SSH_FXP_LSTAT, Size: 65, Number: 3847
Type: SSH_FXP_STATUS, Size: 29, Number: 3847
Opening remote file.
Type: SSH_FXP_OPEN, Size: 73, Number: 4099
Type: SSH_FXP_STATUS, Size: 34, Number: 4099
Status/error code: 3, Message: 4099, Server: Permission denied, Language: ?
(ETerminal) Permission denied.
Error code: 3
Request code: 3
Asking user:
Cannot create remote file '/usr/home/xxx/public_html/xxx.filepart'. ("Permission denied.
Error code: 3
Request code: 3")
(EScpSkipFile) Cannot create remote file '/usr/home/xxx/public_html/xxx.filepart'.
Permission denied.
Error code: 3
Request code: 3
Type: SSH_FXP_OPENDIR, Size: 34, Number: 4363
Type: SSH_FXP_HANDLE, Size: 13, Number: 4363
Type: SSH_FXP_READDIR, Size: 13, Number: 4620
Type: SSH_FXP_NAME, Size: 2945, Number: 4620
Type: SSH_FXP_READDIR, Size: 13, Number: 4876
Type: SSH_FXP_STATUS, Size: 28, Number: 4876
Type: SSH_FXP_CLOSE, Size: 13, Number: 5124
Type: SSH_FXP_STATUS, Size: 24, Number: 5124
Any suggestions?
I do not thing that the problem has anything to do with high port. But from the log I cannot see any other cause, "Permission denied" is too general.
AlexF
After reviewing, your correct. It is not related to the high port. What's funny is that I am using it to login to another home directory (on the same server as a different user)and it is working without a hitch and all the settings in WinSCP are exactly the same. I've tried to remove the profile/session and recreating it (defalt config) and yet nothing.
Any other suggestions?
AlexF
Just to clarify:
In WinSCP, I have two sessions: "Client 1 & Client 2", using default settings. Both clients are on the same ded. server (shared ip).
AlexF
I'M SORRY! Embarassed
Someone changed the permisions on that dir. I feel like an idiot. That should of been the first thing to check. Idea
