Topic "dos batch script prompts me for password"
nickg
I have a little dos batch script to put a file onto the server of one of our vendors. It prompts me for the password though and I do not want prompted. Is there a way for me to automatically get the password read in my dos batch script?
nickg
After searching and searching, I finally found it. I needed PasswordPlain in my .ini file instead of just password.
joelignall
Hi Nick, I believe I am trying to do what you are doing, run script/batch files without being prompted for a password. Would you please send an example. I listed "PasswordPlain" in my script file but still get prompted for a password. The messages do not indicate the remote server refused the key... I am using a script file (with the commands), is this what you refer to as an .ini file? Thx!
Just put your password into session URL in the open command:
http://winscp.net/eng/docs/session_url
joelignall
Thanks, that worked!
