Topic "WINSCP compatible with Win7 64 bit"
EddyP001
hi all,
currently im running with Version 3.8.2 (build 330) on Win XP pro (sp3) 32 bit and i want to know of this one is also working on Win7 64 bit.
Is there a list with winscp version that are working on Win7 64 bit ?
thanks in advance, Eddy
NonaSuomy
I have used both the stable and beta version on win764bit both work fine.
3.8.2 should be working on Windows 7. But you are strongly encouradged to upgrade to the latest stable version.
Priyanka
Is WinSCP 5.1.4 compatible with Windows 7 64-bit?
Thanks.
petervot
Yes, it is.
(Altough winscp 5.5 keeps freezing after about 1 minute of inactivity with the remote server. Reconnection pop up windows appears. Annoying bug, since v5.1.x)
chal5oye
GuL
petervot wrote:
Yes, it is.
Yes. See also http://winscp.net/eng/docs/requirements#client
But if possible, please use the latest version of WinSCP.
