Topic "VBScript works in Windows 7 64-bit Locks in XP WinSCP 5.0.5"
Hi this code works fine on Win7 but not XP not sure if I am doing something wrong but what I get after I run it is a locked command line cursor blink and when I close the window it seems to finish up the script with WinSCP> so looks like its launching but not accepting the scripted params in XP, It also does not spit out a log.txt so there's nothing to help debug it and the script doesnt fail just locks with the blinking cursor.
Dim WshShell, OExec, output
' Setup Shell vars.
Set WshShell = WScript.CreateObject("WScript.Shell")
' Setup WinSCP and capture shell output.
Set oExec = WshShell.Exec(" /log=log.txt")
   "option batch abort" & vbCRLF & _
   "option exclude ""*/; .DS_Store; *.ini; *.tmp; *.mp4>300M; *.avi>300M; *.mpg>300M""" + vbCRLF & _
   "open" + vbCRLF & _
   "synchronize local -delete ""ScreenUpload\"" ""/en/""" + vbCRLF & _
   "exit" + vbCRLF)
' wait until it finishes and collect its output.
output = oExec.StdOut.ReadAll()
' print the output.
Tested winscp435 with same script with no issues, not sure what the deal is with 5.0.5?
I have sent you an emails with link to a debug version.
I have sent you the log just to note it worked fine with this version but at the top of the log it says 5.0.4 not sure if that matters.
Wasn't logged in above... oops Smile
