Topic "bug: synchronizing ignore timezones"
Max
Synchronize window has comparsion criteria "Modification time", but if server has timezone = 0 and client computer timezone = +3hours all our files always marked as modified Sad
tested on WinScp 5.0.5beta
Please read:
http://winscp.net/eng/docs/timestamp
Let me know if it does not help.
Max
I use SCP connection to server with timezone = 0.
Looks like I need setup WinSCP my timezone. But why you can't get it automatically? From server by linux command, from local computer by WinAPI.
thank you.
Max
Maybe we are to each other is not understood correctly? I'll try write here example of my case:
Steps:
1. open SCP connection to any server (in my case my local timezone = +2h, remote server has timezone = 0h)
2. create new directory "test" on local disk
3. create new directory "test2" on remote server
4. copy local "test" to remote server
Expected: on remote server in "Changed"-column time of my dirs/files same as on local disk (for example 19:00).
Actual: on local disk I see time with my timezone (for example 19:00), but on remote server I see time with server timezone (for example 17:00). In result I can't use synchronize files by time.
Current solution: I can setup Enviroment / Server enviroment / Time zone offser = +2h
Questions:
1. not very logical setup time zone offset for "_Server_ enviroment" = +2h, when server has TZ = 0, but _local_ timezone = +2h.
2. is it possible to add option automatically detect difference and use it without manually setup it for each server?
thank you.
What protocol are you using? Really SCP? Have you tried SFTP?
Max
With SFTP almost fine (winscp use timezone, but do not copy changedate with file).
With SCP - problem.
tested on WinSCP 5.2.5
