Topic "FAR Plugin doesn't connect to Sun_SSH"
the FAR-Plugin doesn't connect to my SSH-servers while WinSCP (Version 3.4.2 and 3.5) has no Problem.
The Error message: EAccessViolation
thanks in advance,
log file:
. WinSCP Version 1.1.0 (Build 54)
. Login time: Mittwoch, 14. Januar 2004 15:48:34
. Session name: kresse@sunhalle11
. Host name: sunhalle11 (Port: 22)
. User name: kresse (Password: No, Key file: No)
. Transfer Protocol: SCP
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Alias LS: No, Ign LS warn: Yes, Scp1 Comp: Yes
. Looking up host "sunhalle11"
. Connecting to port 22
. Server version: SSH-2.0-Sun_SSH_1.0
. We claim version: SSH-2.0-WinSCP-FAR-release-1.1
. Host key fingerprint is:
. ssh-rsa 1024 4c:ef:36:60:13:9e:30:9a:50:1e:fa:60:cc:14:5e:bd
. Initialised AES-128 client->server encryption
. Initialised AES-128 server->client encryption
. Attempt to close connection due to fatal exception:
* Authentication failed.
* (EAccessViolation) EAccessViolation
. Closing connection.
It is probably not connected to Sun, as the problem is similar to one reported in:
- Far plugin dos'n connect to winsshd
I'll try to fix this.
