Topic "Some UTF-8 symbols can't be shown"
eirnym
For example, й can be represented with 0439 and with 0438+0306. Second one is usually shown as и? rather than й and this files can't be copied.
What version of WinSCP are you using? Have you tried 5.0.5 beta?
eirnym
In 5.0.5 it's correct, but I have to force make connections UTF-8 (can I do it per session?). The target system is Mac OS X Lion, which is same as FreeBSD 10-CURRENT
Please post a log file showing connection start.
Sure.
