Topic ""Invalid access to memory" after resuming from sleep"
matt99
Winscp 5.05 (Build 1782)
If I have a WinSCP session open when the computer goes to sleep, I get "Invalid Access to Memory" when Windows resumes.
I have sent you a link with a debug version.
Alex, the Marrch Ca'at
Good day to you. I'm having the same problem - after restoring from Hibernate mode, WinSCP dispalyes 2 or 3 "Invalid access to memory" messages then crashes. I'd be glad to provide you with any additional info, including debug logs from any debug build you provide, if you still need it. My email is alexsvetalena--(at)--mail--ru
I have sent you an email with link to a debug version.
BuggB
I'm getting "Invalid accesst to memory" errors not only after resuming, but it happens as well when you disconnect your connection (either turn off wifi or just plug off lan cable) and trying to reconnect after switching your connections back on. It happens with every version i tried. Really very annoying problem. I'm using Win7 32bit, I don't remember it happened when i was using WinXP.
BuggB
Thanks for the reply! You can send email directly to one of my non-spam-filtered address at: spambin~at~mail ru
mtylerb
I have gotten this same error. Either when I disconnect the Wi-Fi or resume from sleep mode. No hibernate on this laptop. I also have another bug, but I'll make a new post for that.
MrCoffee
I'm also getting the same error. Win7 64bit. 5.0.6 Build 2074
