Topic "closing connection when connected to university network"
adam
hello,
Ive read a LOT about "Server unexpectedly closed connection" error, because im getting one. Its a bit weird, because it is bound with a certain strange thing i am in college, and this error seems to appear ONLY when im in my room. when i go to another building (the same network though), everything works fine. I even tried different laptop to use my network cable and my network connection in my place, and IT WORKED. The only problem seems to by my laptop in my room. My laptop in any other room is fine.
Ive tried this in W7, ubuntu 11-10 and another W7 system (format). I DO NOT QUITE SEE THE POINT OF THIS and im really desperate. My network administrator seems to be loosing it, as he "doesnt really know how is that possible". This is my error log:
. 2011-11-29 21:48:23.677 WinSCP Version 4.2.9 (Build 938) (OS 6.1.7601 Service Pack 1)
. 2011-11-29 21:48:23.677 Login time: 29 November 2011 09:48:23 PM
. 2011-11-29 21:48:23.677 --------------------------------------------------------------------------
. 2011-11-29 21:48:23.677 Session name: Blah/blah@blah.blah
. 2011-11-29 21:48:23.678 Host name: blah.blah (Port: 22)
. 2011-11-29 21:48:23.678 User name: blah (Password: Yes, Key file: No)
. 2011-11-29 21:48:23.678 Tunnel: No
. 2011-11-29 21:48:23.678 Transfer Protocol: SCP
. 2011-11-29 21:48:23.678 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-11-29 21:48:23.678 Proxy: none
. 2011-11-29 21:48:23.678 SSH protocol version: 2; Compression: No
. 2011-11-29 21:48:23.678 Bypass authentication: No
. 2011-11-29 21:48:23.678 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-11-29 21:48:23.678 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-11-29 21:48:23.678 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-11-29 21:48:23.678 SFTP Bugs: -,-
. 2011-11-29 21:48:23.678 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-11-29 21:48:23.678 Shell: default
. 2011-11-29 21:48:23.678 EOL: 0, UTF: 2
. 2011-11-29 21:48:23.678 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-11-29 21:48:23.678 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-11-29 21:48:23.678 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-11-29 21:48:23.679 Cache directory changes: Yes, Permanent: Yes
. 2011-11-29 21:48:23.679 DST mode: 1
. 2011-11-29 21:48:23.679 --------------------------------------------------------------------------
. 2011-11-29 21:48:23.755 Looking up host "blah.blah"
. 2011-11-29 21:48:23.757 Connecting to blah.blah.blah.blah port 22
. 2011-11-29 21:48:23.763 Selecting events 63 for socket 584
. 2011-11-29 21:48:23.767 Waiting for the server to continue with the initialisation
. 2011-11-29 21:48:23.767 Looking for incoming data
. 2011-11-29 21:48:23.767 Looking for network events
. 2011-11-29 21:48:23.767 Detected network event
. 2011-11-29 21:48:23.767 Enumerating network events for socket 584
. 2011-11-29 21:48:23.767 Enumerated 18 network events making 18 cumulative events for socket 584
. 2011-11-29 21:48:23.768 Handling network write event on socket 584 with error 0
. 2011-11-29 21:48:23.768 Handling network connect event on socket 584 with error 0
. 2011-11-29 21:48:23.768 Looking for network events
. 2011-11-29 21:48:28.786 Detected network event
. 2011-11-29 21:48:29.288 Enumerating network events for socket 584
. 2011-11-29 21:48:29.288 Enumerated 32 network events making 32 cumulative events for socket 584
. 2011-11-29 21:48:29.288 Handling network close event on socket 584 with error 0
. 2011-11-29 21:48:29.288 Selecting events 0 for socket 584
. 2011-11-29 21:48:29.288 Server unexpectedly closed network connection
* 2011-11-29 21:48:29.295 (ESshFatal) Server unexpectedly closed network connection.
thank you very much for any help in this "ESshFatal" problem. really, i appreciate it.
It's difficult to give any hint here. Can you try to disable your Windows firewall temporarily? Is there anything in the server's log what may give some hint?
