Topic "Problem during loggin - group command"
resmiki
I use WinSCP to communicate with network player Xtreamer. It's based on linux. Every time after login I see message:
Quote:
Command 'groups'
failed with return code 127 and error message
-sh: groups: not found.
Probably this system doesn't support group command.
Is it possible to disable this command at loging ?
Except this WinSCP is very useful. Thank You.
Bogdan Kot
Poland
resmiki
I'v found solution. Problem doesn't exists. Very Happy
spongman
^^ waste of air.
I'm also seeing this non-existent problem.
My remote system doesn't have the 'groups' command and I keep getting this annoying popup when connection.
please an option to ignore this error, or fallback to parsing the /etc/group file directly if absolutely necessary.
spongman
. 2012-01-21 01:26:14.766 Looking up groups and users.
> 2012-01-21 01:26:14.766 groups ; echo "WinSCP: this is end-of-file:$?"
! 2012-01-21 01:26:14.812 -sh: groups: not found
< 2012-01-21 01:26:14.829 WinSCP: this is end-of-file:127
* 2012-01-21 01:26:14.829 (ECommand) Error looking up user groups.
* 2012-01-21 01:26:14.829 Command 'groups'
* 2012-01-21 01:26:14.829 failed with return code 127 and error message
* 2012-01-21 01:26:14.829 -sh: groups: not found.
. 2012-01-21 01:26:16.989 Getting current directory name.
Please read documentation:
http://winscp.net/eng/docs/ui_login_scp
