Topic "Synchronize all subdirectories with criteria"
Moy
I want to save an entire site, except certain directories. I run a script the first time, it saves everything correctly. But if I run the script, the site is still saved between, ignoring the parameter "criteria". Why ?
option batch abort
My script:
option reconnecttime 5
option include "/*/*|Sve/;_*/"
synchronize local -delete -criteria=either "S:\MyLocalDirectory\" /MyServerDirectory
Thanks for your help.
How does the "ingnoring" manifest?
Moy
When I run the script, always backup all files / directories
Would this FAQ help?
http://winscp.net/eng/docs/faq_synchronize
Moy
It does not help me Sad
When "Criteria" is "size", it also copies the entire site every time.
Quote:
option batch abort
synchronize local -delete -criteria=size "S:\Sauvegarde sites en ligne\MyChessNet_Donnees\MyChessNet\" /MyChessNet
The Log is :
Quote:
2011-12-15 18:52:05.550 --------------------------------------------------------------------------
. 2011-12-15 18:52:05.550 WinSCP Version 5.0.5 (Build 1782) (OS 5.1.2600 Service Pack 3)
. 2011-12-15 18:52:05.550 Configuration: D:\Utils\Winscp\WinSCP.ini
. 2011-12-15 18:52:05.550 Local account: VENDOME\Anthony
. 2011-12-15 18:52:05.550 Login time: jeudi 15 dcembre 2011 18:52:05
. 2011-12-15 18:52:05.550 --------------------------------------------------------------------------
. 2011-12-15 18:52:05.550 Session name: mychessnet (Modified stored session)
. 2011-12-15 18:52:05.550 Host name: ftpperso.free.fr (Port: 21)
. 2011-12-15 18:52:05.550 User name: mychessnet (Password: Yes, Key file: No)
. 2011-12-15 18:52:05.550 Tunnel: No
. 2011-12-15 18:52:05.550 Transfer Protocol: FTP
. 2011-12-15 18:52:05.550 Ping type: C, Ping interval: 30 sec; Timeout: 5 sec
. 2011-12-15 18:52:05.550 Proxy: none
. 2011-12-15 18:52:05.550 FTP: FTPS: None; Passive: Yes [Force IP: No]
. 2011-12-15 18:52:05.550 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-12-15 18:52:05.550 Cache directory changes: Yes, Permanent: Yes
. 2011-12-15 18:52:05.550 DST mode: 1
. 2011-12-15 18:52:05.550 Connecting to ftpperso.free.fr ...
. 2011-12-15 18:52:05.566 Connected with ftpperso.free.fr. Waiting for welcome message...
< 2011-12-15 18:52:05.628 220 Serveur de mise a jour des pages perso de Free.fr version [Apr 27 2011 11:43:55]
> 2011-12-15 18:52:05.628 USER mychessnet
< 2011-12-15 18:52:05.675 331 Password required for mychessnet.
> 2011-12-15 18:52:05.675 PASS ******
< 2011-12-15 18:52:05.706 230 User mychessnet logged in.
> 2011-12-15 18:52:05.706 SYST
< 2011-12-15 18:52:05.738 215 UNIX Type: L8
> 2011-12-15 18:52:05.738 FEAT
< 2011-12-15 18:52:05.769 500 'FEAT': command unrecognized.
. 2011-12-15 18:52:05.769 Connected
. 2011-12-15 18:52:05.769 --------------------------------------------------------------------------
. 2011-12-15 18:52:05.769 Using FTP protocol.
. 2011-12-15 18:52:05.769 Doing startup conversation with host.
> 2011-12-15 18:52:05.769 PWD
< 2011-12-15 18:52:05.800 257 "/" is current directory.
. 2011-12-15 18:52:05.800 Getting current directory name.
. 2011-12-15 18:52:05.800 Startup conversation with host finished.
< 2011-12-15 18:52:05.800 Script: Active session: [1] mychessnet
> 2011-12-15 18:52:05.800 Script: option batch abort
< 2011-12-15 18:52:05.800 Script: batch abort
> 2011-12-15 18:52:05.800 Script: option reconnecttime 5
< 2011-12-15 18:52:05.800 Script: reconnecttime 5
> 2011-12-15 18:52:05.800 Script: option include "/*/*|Sve/;_*/"
< 2011-12-15 18:52:05.800 Script: include /*/*|Sve/;_*/
> 2011-12-15 18:52:05.800 Script: synchronize local -delete -criteria=size "S:\Sauvegarde sites en ligne\MyChessNet_Donnees\MyChessNet\" /MyChessNet
< 2011-12-15 18:52:05.800 Script: Comparing...
. 2011-12-15 18:52:05.800 Collecting synchronization list for local directory 'S:\Sauvegarde sites en ligne\MyChessNet_Donnees\MyChessNet\' and remote directory '/MyChessNet', mode = 1, params = 1539
. 2011-12-15 18:52:05.816 Retrieving directory listing...
> 2011-12-15 18:52:05.816 CWD /MyChessNet/
< 2011-12-15 18:52:05.847 250 CWD command successful.
> 2011-12-15 18:52:05.847 PWD
< 2011-12-15 18:52:05.878 257 "/MyChessNet" is current directory.
> 2011-12-15 18:52:05.878 TYPE A
< 2011-12-15 18:52:05.910 200 Type set to A
> 2011-12-15 18:52:05.910 PASV
< 2011-12-15 18:52:05.941 227 Entering Passive Mode (212,27,63,3,224,52).
> 2011-12-15 18:52:05.941 LIST -a
< 2011-12-15 18:52:05.972 150 Opening ASCII mode data connection for file list
< 2011-12-15 18:52:06.144 226 Transfer complete.
. 2011-12-15 18:52:06.144 Directory listing successful
< 2011-12-15 18:52:06.160 Script: Synchronizing...
. 2011-12-15 18:52:06.160 Synchronizing local directory 'S:\Sauvegarde sites en ligne\MyChessNet_Donnees\MyChessNet\' with remote directory '/MyChessNet/', params = 1539
. 2011-12-15 18:52:06.160 File: "/MyChessNet/1044649334"
< 2011-12-15 18:52:06.160 Script: Local 'S:\Sauvegarde sites en ligne\MyChessNet_Donnees\MyChessNet' <= Remote '/MyChessNet'
. 2011-12-15 18:52:06.160 Retrieving directory listing...
> 2011-12-15 18:52:06.160 CWD /MyChessNet/1044649334/
< 2011-12-15 18:52:06.191 250 CWD command successful.
> 2011-12-15 18:52:06.191 PWD
< 2011-12-15 18:52:06.222 257 "/MyChessNet/1044649334" is current directory.
> 2011-12-15 18:52:06.222 TYPE A
< 2011-12-15 18:52:06.253 200 Type set to A
> 2011-12-15 18:52:06.253 PASV
< 2011-12-15 18:52:06.300 227 Entering Passive Mode (212,27,63,3,231,32).
> 2011-12-15 18:52:06.300 LIST -a
< 2011-12-15 18:52:06.331 150 Opening ASCII mode data connection for file list
< 2011-12-15 18:52:06.535 226 Transfer complete.
. 2011-12-15 18:52:06.535 Directory listing successful
. 2011-12-15 18:52:06.535 File: "/MyChessNet/1044649334/AvatarJ2.jpg"
. 2011-12-15 18:52:06.535 Copying "/MyChessNet/1044649334/AvatarJ2.jpg" to local directory started.
. 2011-12-15 18:52:06.535 Binary transfer mode selected.
. 2011-12-15 18:52:06.535 Starting download of /MyChessNet/1044649334/AvatarJ2.jpg
> 2011-12-15 18:52:06.550 TYPE I
< 2011-12-15 18:52:06.581 200 Type set to I
> 2011-12-15 18:52:06.581 PASV
< 2011-12-15 18:52:06.613 227 Entering Passive Mode (212,27,63,3,187,63).
> 2011-12-15 18:52:06.613 RETR AvatarJ2.jpg
< 2011-12-15 18:52:06.644 150 Opening BINARY mode data connection for AvatarJ2.jpg (4698 bytes)
< 2011-12-15 18:52:06.847 226 Transfer complete.
. 2011-12-15 18:52:06.847 Download successful
I fear this is a bug in WinSCP.
Moy
I sent the mail Friday 16.
I have replied on Wed.
