Topic "Scripting with XML logging, not appending file"
Rickardh
Hi I'm using scripting of WINSCP with XML logging. The problem is that the file is overwritten each time it logs.
In the GUI I can see a button "append to file", is this option available with scripting?
Using version: 4.2.9
Command call:
"C:\Program Files (x86)Winscp\WinSCP.com" /script="D:\ftpscripts\ftp_getfilesWithMove.bat" /parameter /fromFolder/ D:\ToFolder\ *.xml /xmllog=D:\Log\Log.xml
The Script looks like:
option batch abort
open ftp://user:password@server:port -passive
cd %1%
lcd %2%
lpwd
get %3%
mv %3% ./Archive/
Regards,
Rickard
You cannot append XML logs. If would create invalid XML.
You can create different log for every run with !T pattern:
http://winscp.net/eng/docs/ui_pref_logging
