Topic "Put with Delete to move and delete all files but not folders"
I would like to PUT all files in a folder/subfolder structure to the remote site, and then delete all the files, but not the folder structure. So far I've been able to PUT everything and delete everything, but have not yet figured out how to keep the folder structure intact.
Any help would be appreciated.
You have to delete the files one by one. There's no magic for that in WinSCP.
Assuming your file source is unix...
After you have copied the files, run a remote command
The "type -f" filter will limit the results to files
find /path/to/root/file/source -type f -exec rm {}\;
find is a recursive command and it will delete EVERY file under the path you name (so don't use / or .)
