Topic "Use cygwin and openssh instead of putty."
kirs
WinSCP has nice putty integration - you can open Putty window and it will pass username/key/password etc.
Is it possible to use cygwin and openssh same way?
How to integrate WinSCP with openssh? What kind of command place in preferences->Putty path?
Thanks!
It's not possible.
prikryl wrote:
It's not possible.
I was able to create custom command to run ssh. But it has limitations - I can't make it auth with rsa key - because it doesn't load current user in cygwin and it has no permissions to key file. But it works with regular user:password auth:
c:\cygwin\bin\mintty /bin/ssh !U:!P@!@
This one fails with permissions denied:
c:\cygwin\bin\mintty /bin/ssh !U:!P@!@ -I /home/user/.ssh/id_dsa
I have command which works if run from windows run menu:
c:\cygwin\bin\mintty /bin/bash -c 'ssh user@host'
But this one doesn't work if run as custom command in WinSCP
Can you help to make it working?
Also - it would be cool to have "port" pattern in custom commands.
So what happens if you execute the custom command?
Artistan
I wrote up an article here on how to use custom commands to launch cygwin terminals, mintty.
http://blog.geekslikeshinythings.com/2013/08/winscp-and-cygwin.html
Thanks for sharing this.
Actually since WinSCP 5.2.2 beta you can sneak in Cygwin instead of PuTTY for the Open in PuTTY command as you can now use the !U@!@ even in the path to PuTTY.
I have documented this now:
http://winscp.net/eng/docs/integration_app#cygwin
