Topic "WinSCP unable to open any files"
Abc123
When i am using WinSCP trying to open files on my open it doesnt open when i right click it the choice to open and to edit does not work either
Oops i meant When i am using WinSCP trying to open files on my IPOD it doesnt open. When i right click a file the choice to open and to edit the file does not work either
What does it mean "does not work"? Can you give us more details?
So basically when i try to double click a folder i want to open. The folder doesnt open it just stays on the same screen
Maybe few screenshots (video would be the best), may help me to understand the problem. Thanks.
http://i44.tinypic.com/66kqjd.jpg
And
http://i39.tinypic.com/2rhocgo.jpg
So as you can see in both images that the choice to open the file is greyed out[/b]
It is a directory, not a file. Double-click the directory to see the files inside and open the one you want.
Double clicking the directory doesnt do anything either it wont open it
Asuca_
alright i sent an email
