Topic "Scrolling panes on mouse over"
CaioToOn!
Currently, you have to select the pane (remote or local) to scroll with mouse wheel. It would be nice with on mouse over on the pane the mouse scroll that pane, not the selected one. Seems like a simple implementation, but might be wrong.
Also, would be nice if it try to keep the same scrolling after an file upload.
Cheers,
CaioToOn!
This is actually specific to Windows version your are running. On XP this is not supported. On Win7 for instance it works as you ask for.
