Topic "Not all Special characters are correct -> transfer fail"
rdsutter
I have a file on a server with as name
"Beşiktaş Kulb"
but this file is displayed as
"Besiktas Kulb"
When trying to transfer the file, the message "The system cannot find the file specified" appears.
However, in the same folder (!), other files with special characters are displayed and transferred correctly. These have file names like:
"FENERBAHE"
"NK IROKI BRIJEG1"
"Brndby"
I've tried to change the UTF-8 setting (on/off/auto), but this doesn't change the result.
Other programs (e.g., Plesk), displays the filename correct (with the ş characters).
Please help how to transfer these files (without having to rename them directly on the server)
Kind regards.
prikryl
Have you tried 5.0.x beta?
I've tried both in the latest version 4.3.6 and in version 5.0.5 beta. Both versions experienced exactly the same problem.
prikryl
To generate log file, enable logging, log in to your server and do the operation and only the operation that causes the error. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
adirse
here are the log:
. 2012-01-23 10:27:01.654 Copying 1 files/directories to remote directory "/home/panacea/Medicine/"
. 2012-01-23 10:27:01.654 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2012-01-23 10:27:01.654 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2012-01-23 10:27:01.659 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2012-01-23 10:27:01.659 File: "C:\P\????"
* 2012-01-23 10:27:01.734 (EOSError) System Error. Code: 123.
* 2012-01-23 10:27:01.739 The filename, directory name, or volume label syntax is incorrect
. 2012-01-23 10:27:01.739 Asking user:
. 2012-01-23 10:27:01.739 File or folder 'C:\P\????' does not exist. ("System Error. Code: 123.
. 2012-01-23 10:27:01.739 The filename, directory name, or volume label syntax is incorrect")
* 2012-01-23 10:27:04.689 (EScpSkipFile) File or folder 'C:\P\????' does not exist.
* 2012-01-23 10:27:04.689 System Error. Code: 123.
* 2012-01-23 10:27:04.689 The filename, directory name, or volume label syntax is incorrect
. 2012-01-23 10:27:04.694 Listing directory "/home/panacea/Medicine".
> 2012-01-23 10:27:04.694 Type: SSH_FXP_OPENDIR, Size: 31, Number: 8406027
< 2012-01-23 10:27:04.694 Type: SSH_FXP_STATUS, Size: 24, Number: 8405764
. 2012-01-23 10:27:04.694 Discarding reserved response
< 2012-01-23 10:27:04.699 Type: SSH_FXP_HANDLE, Size: 13, Number: 8406027
> 2012-01-23 10:27:04.699 Type: SSH_FXP_READDIR, Size: 13, Number: 8406284
< 2012-01-23 10:27:04.704 Type: SSH_FXP_NAME, Size: 1361, Number: 8406284
> 2012-01-23 10:27:04.709 Type: SSH_FXP_READDIR, Size: 13, Number: 8406540
< 2012-01-23 10:27:04.714 Type: SSH_FXP_STATUS, Size: 28, Number: 8406540
< 2012-01-23 10:27:04.714 Status code: 1
> 2012-01-23 10:27:04.714 Type: SSH_FXP_CLOSE, Size: 13, Number: 8406788
. 2012-01-23 10:27:12.519 Closing connection.
. 2012-01-23 10:27:12.519 Sending special code: 12
. 2012-01-23 10:27:12.519 Sent EOF message
prikryl
I cannot even tell what version of WinSCP this one is from. Thanks.
