Topic "How to sftp without storing any session"
vichu
I try to connect to sftp thru command line interface. when connecting first time it ask me Do you want to add the host key to cache? (Yes,No,Cancel,Copy Key).
How to force the script to always select "No" option.
My script is
winscp.com /console /command "option batch on" "option confirm off" "open user:pwd@myServer -privatekey=""C:\temp\myprivateKey.ppk""" "cd Upload" "put My SFTPTest.txt" "exit" /log="C:\temp\Winscp.log"
Thanks in advance
Please read documentation:
http://winscp.net/eng/docs/message_host_key
vichu
Thanks for your reply.
I am able to connect with -hostkey option. I like to know how to get the -hostkey information from privatekey using winscp command or script.
Hostkey is not stored in the private key. Host key is public key of the server. Private key is not specific to the server.
vichu
Thanks. I can able to get HostKey detail from PUTTYGen by importing the privatekey. I like to know how to get the hostkey information using Script.
You are not suppoed to get hostkey by the script. You should know the hostkey before and use it in the script.
Please read:
http://winscp.net/eng/docs/ssh
vichu
Please read:
http://winscp.net/eng/docs/ssh[/quote]
Thanks Prikryl. I will save the session first and then use it thru my script.
