Topic "WinSCP fails opening local directory"
Gutza
I'm using WinSCP 4.3.6 on Windows 7/64; the problem was manifesting itself in the previous version as well (I upgraded hoping this would fix itself, but no joy).
The problem is that WinSCP simply refuses to open some local directories (yes, local!) Double-clicking the directory does nothing, right-clicking HIDES the directory from the panel (although right-clicking on another directory or refreshing makes it reappear), and if I try to drag content from the "forbidden" directory (opened in Windows Explorer) to the remote pane I get an error saying "System Error. Code: 3. The system cannot find the path specified".
In reality the path is very much available, and there are no special permission issues that I'm aware of (I open those directories in Windows Explorer in the usual way, with no acrobatics whatsoever); the files therein are also quite bland, there's absolutely nothing special about them (they aren't huge, there aren't a lot of them, there's just nothing special about those directories).
Gutza
Sent.
Gutza
I haven't received anything. However, I just realized the problem might be related to SpiderOak, because (1) I've never experienced this before installing SpiderOak, (2) it only appears to happen in directories synchronized with SpiderOak, and (3) I've been able to reproduce it on Windows XP, for directories synched with SpiderOak (the original report was related to Windows 7).
SpiderOak does provide a free version, so I think you should be able to replicate the problem yourself. Please let me know if you need further input, I'd be glad to help.
Gutza
For the record, I have sent in two traces a couple of days ago via e-mail.
Got it, will reply in few days.
Gutza
For the record, Martin sent me a dev version that worked. Yay, thank you Martin!
Gutza
Final update on this one: after a few more e-mail exchanges with Martin, it appears that none of the 5.x versions exhibit the behavior I complained about. Unfortunately 5.x is in beta for the time being, but if you encounter this issue at least you have a way out.
